三菱伺服驱动器 MR-J4-B 用户使用手册 中文高清版
《三菱伺服驱动器 MR-J4-B 用户使用手册 中文高清版》
文档目录为:
第1章 功能和配置
1 1  概要 ··········································································
1 2  功能逻辑框图 ····························································
1 3  伺服放大器标准规格 ·················································
1 4  伺服放大器与伺服电机的组合 ···································
1 5  功能一览 ···································································
1 6  型号的构成 ·······························································
1 7  结构 ··········································································
1 7 1各部位的名称 ····················································
1 7 2正面盖板的拆卸与安装 ·····································
1 8  配套设备的构成 ························································
第2章 安装
2 1  安装方向与间隔 ························································
2 2  防止异物进入 ····························································
2 3  编码器电缆强度 ························································
2 4 SCNETⅢ电缆的布线················································
2 5  检查项目 ···································································
2 6  具有使用寿命的部件 ·················································
第3章 信号与配线
3 1  电源系统回路的连接示例 ··········································
3 2  输入输出信号的连接示例 ··········································
3 2 1  漏输入输出接口的情况 ·································
3 2 2  源输入输出接口的情况 ·································
3 3  电源类的说明 ····························································
3 3 1  信号的说明 ···················································
3 3 2  通电程序·······················································
3 3 3 CNP1,CNP2以及CNP3的配线方法 ············
3 4  接口与信号排列 ························································
3 5  信号(元件)的说明 ······················································
3 5 1  输入元件·······················································
3 5 2  输出元件·······················································
3 5 3  输出信号·······················································
3 5 4  电源 ······························································
3 6  强制停止减速功能的说明 ··········································
3 6 1  强制停止减速功能(SS1) ·······························
3 6 2  基座切断延迟功能 ········································
3 6 3  上下轴拉升功能 ············································
3 6 4  使用EM2的强制停止功能的残留风险 ···········
3 7  报警发生时的时序图 ·················································
3 7 1  使用强制停止减速功能时······························
3 7 2  不使用强制停止减速功能时 ··························
3 8  接口 ··········································································
3 8 1  内部连接图 ···················································
3 8 2  接口的详细说明 ············································
3 8 3  源输入输出接口 ·······················································
3 9 SSCNETⅢ电缆的连接 ························································
3 10  带电磁制动器伺服电机 ························································
3 10 1  注意事项··································································
3 10 2  时序图 ·····································································
3 11  接地 ·····················································································
第4章 启动
4 1首次接通电源时 ·······································································
4 1 1  启动步骤··································································
4 1 2  配线的检查 ······························································
4 1 3  周围环境··································································
4 2  启动 ·····················································································
4 3  伺服放大器的开关设定与显示部位 ······································
4 3 1开关 ·············································································
4 3 2  滚动显示··································································
4 3 3  轴的状态显示 ··························································
4 4  试运行 ·················································································
4 5  试运行模式 ··········································································
4 5 1 MR Configurator2的试运行模式 ······························
4 5 2  控制器的无电机运行 ················································
第5章 参数
5 1  参数一览 ··············································································
5 1 1  基本设定参数([Pr PA_ _ ]) ·······································
5 1 2  增益滤波器设定参数([Pr PB_ _ ]) ····························
5 1 3  扩展设定参数([Pr PC_ _ ])·······································
5 1 4  输入输出设定参数([Pr PD_ _ ]) ·······························
5 1 5  扩展设定2参数([Pr PE_ _ ]) ·····································
5 1 6扩展设定3参数([Pr PF_ _ ]) ·········································
5 1 7  直线伺服电机/直驱电机设定参数([Pr PL_ _ ])  ··········
5 2参数详情一览 ···········································································
5 2 1  基本设定参数([Pr PA_ _ ]) ·······································
5 2 2  增益滤波器设定参数([Pr PB_ _ ]) ····························
5 2 3  扩展设定参数([Pr PC_ _ ])·······································
5 2 4  输入输出设定参数([Pr PD_ _ ]) ·······························
5 2 5扩展设定2参数([Pr PE_ _ ]) ·········································
5 2 6  扩展设定3参数([Pr PF_ _ ]) ·····································
5 2 7  直线伺服电机/直驱电机设定参数([Pr PL_ _ ])  ··········
第6章 一般增益调整
6 1调整方法的种类 ·······································································
6 1 1  伺服电机单体的调整 ················································
6 1 2  基于MR Configurator2的调整 ··································
6 2  一键式调整 ··········································································
6 2 1  一键式调整的流程 ···················································
6 2 2  一键式调整的显示变化/操作方法 ·····························
6 2 3  一键式调整时的注意 ················································
6 3  自动调整 ······································································
6 3 1  自动调整模式 ··················································
6 3 2  自动调整模式的基础 ········································
6 3 3  自动调整的调整步骤 ········································
6 3 4自动调整模式的响应性设定 ·································
6 4  手动模式 ······································································
6 5 2增益调整模式 ·····························································
第7章 特殊调整功能
7 1  滤波器设定 ··································································
7 1 1  机械共振抑制滤波器 ········································
7 1 2  自适应滤波器Ⅱ ···············································
7 1 3  轴共振抑制滤波器 ···········································
7 1 4  低通滤波器 ······················································
7 1 5  高级减震控制Ⅱ ···············································
7 1 6  指令陷波滤波器 ···············································
7 2  增益切换功能 ·······························································
7 2 1  用途 ·································································
7 2 2  功能逻辑框图 ··················································
7 2 3  参数 ·································································
7 2 4  增益切换的步骤 ···············································
7 3  强制驱动功能 ·······························································
7 3 1  振动强制驱动功能 ···········································
7 3 2  瞬停强制驱动功能 ···········································
第8章  故障排查
8 1  报警/警告一览表 ··························································
8 2  通电时的故障排查 ·······················································
第9章 外形尺寸图
9 1  伺服放大器 ··································································
9 2  接插件 ·········································································
第10章 特性
10 1  过载保护特性 ·······························································
10 2  电源设备容量与发生损失 ·············································
10 3  动态制动器特性 ···························································
10 3 1  关于动态制动器的制动 ····································
10 3 2  使用动态制动器时的容许负载惯量矩 ···············
10 4电缆弯曲寿命 ·································································
10 5  主回路/控制回路通电时的浪涌电流 ·····························
第11章  选件/配套设备
11 1电缆/接插件组 ································································
11 1 1  电缆/接插件组的组合 ·······································
11 1 2 MR-D05UDL3M-B STO电缆 ···························
11 1 3 SSCNETⅢ电缆  ·················································································
11 2  再生选件 ········································································································
11 2 1  组合与再生电力 ·················································································
11 2 2再生选件的选择 ···················································································
11 2 3  参数的设定 ························································································
11 2 4  再生选择件的连接 ·············································································
11 2 5  外形尺寸图 ························································································
11 3 FR-BU2制动模块 ···························································································
11 3 1  选择 ···································································································
11 3 2  制动模块的参数设定 ··········································································
11 3 3  连接示例····························································································
11 3 4  外形尺寸图 ························································································
11 4 FR-RC电源再生转换器 ··················································································
11 5 FR-CV电源再生共通转换器 ···········································································
11 6  中继端子台PS7DW-20V14B-F(推荐用品)  ······················································
11 7 MR Configurator2 ··························································································
11 8  电池 ···············································································································
11 9  电线选择示例 ·································································································
11 10 无熔丝断路器/保险丝/电磁接触器(推荐用品) ·················································
11 11 功率因素改善DC电抗器 ·················································································
11 12 功率因素改善电抗器 ······················································································
11 13 继电器(推荐品) ······························································································
11 14 噪声对策 ········································································································
11 15 漏电断路器 ····································································································
11 16 EMC滤波器(推荐用品) ···················································································
第12章 绝对位置检测系统
12 1  特点 ···············································································································
12 2  规格 ···············································································································
12 3  电池的更换方法 ·····························································································
12 4电池的拆装方法 ·······························································································
12 5绝对位置检测数据的确认 ·················································································
第13章 使用STO功能时
13 1  前言 ···············································································································
13 1 1  概要 ···································································································
13 1 2  安全相关用语的说明 ··········································································
13 1 3  注意 ···································································································
13 1 4 STO功能的残留风险 ·········································································
13 1 5  规格 ···································································································
13 1 6  维护/保养···························································································
13 2 STO输入输出信号接插件(CN8)与信号排列 ···················································
13 2 1  信号排列····························································································
13 2 2  信号(元件)的说明 ··············································································
13 2 3 STO电缆的拔除方法 ·········································································
13 3  连接示例 ········································································································
13 3 1 CN8接插件连接示例 ··········································································
13 3 2  使用MR-J3-D05安全逻辑模块时外部输入输出信号连接示例  ·············
13 3 3  使用外部安全继电器时的外部输入输出信号连接示例 ························
13 3 4  使用动作控制器时的外部输入输出信号连接示例 ··················
13 4  接口的详细说明 ················································································
13 4 1  漏输入输出接口 ····································································
13 4 2  源输入输出接口 ····································································
第14章 使用直线伺服电机时
14 1  功能与结构 ·······················································································
14 1 1  概要 ······················································································
14 1 2  配套设备与结构 ····································································
14 2  信号与配线 ·······················································································
14 3  运行与功能 ·······················································································
14 3 1  启动 ······················································································
14 3 2磁极检测 ·················································································
14 3 3  原点复归···············································································
14 3 4 MR Configurator2的试运行模式 ···········································
14 3 5  基于控制器的运行 ································································
14 3 6  功能 ······················································································
14 3 7  绝对位置检测系统 ································································
14 4  特性 ··································································································
14 4 1过载保护特性 ··········································································
14 4 2  电源设备容量与发生损失······················································
14 4 3动态制动器特性 ······································································
14 4 4  使用动态制动器时的容许荷重比 ···········································
第15章  使用直驱电机时
15 1  功能与结构 ·······················································································
15 1 1  概要 ······················································································
15 1 2配套设备与结构 ······································································
15 2  信号与配线 ·······················································································
15 3  运行与功能 ·······················································································
15 3 1  启动步骤···············································································
15 3 2  磁极检测···············································································
15 3 3  基于控制器的运行 ································································
15 3 4功能 ························································································
15 4  特性 ··································································································
15 4 1  过载保护特性 ·······································································
15 4 2  电源设备容量与发生损失······················································
15 4 3动态制动器特性 ······································································
第16章  使用全封闭系统时(预定支持)
16 1  功能与结构 ·······················································································
16 1 1  功能逻辑框图 ·······································································
16 1 2  控制模块的选择步骤 ·····························································
16 1 3  系统结构···············································································
16 2  机械端编码器 ····················································································
16 2 1  直线编码器 ···········································································
16 2 2  旋转编码器 ···········································································
16 2 3  编码器电缆结构图 ································································
16 2 4 MR-J4FCCBL03M分支电缆 ················································
16 3  运行与功能 ······················································································
16 3 1  启动 ·····················································································
16 3 2  原点复归··············································································
16 3 3基于控制器的运行  ··································································
16 3 4  全封闭控制异常检测功能·····················································
16 3 5  全封闭系统中的绝对位置检测系统 ······································
16 3 6 MR Configurator216 - 22
附件
附1  配套设备制造商(参考用) ··································································
附2  联合国《关于危险货物运输的建议书》中的AC伺服放大器电池的标
附3  欧洲新电池指令的符合标志  ···························································
附4 CE标志的符合  ···············································································
附5 UL/CSA标准的符合 ········································································
附6  KC标准的符合  ···············································································
附7 MR-J3-D05安全逻辑模块   ·······························································
附8  EC declaration of conformity ···························································
附9  伺服放大器的谐波抑制对策  ···························································
附10 不进行磁极检测的伺服放大器更换  ·················································
附11 HG-MR・HG-KR用2线式编码器电缆 ················································
附12 三菱电机系统服务产SSCNETⅢ电缆(SC-J3BUS_M-C) ··················
附13 模拟监视器 ······················································································
大神点评(5)
编程吧网友  发表于 2018-7-23 18:02:03
不错,好的资料不多。感谢提供
使用道具
编程吧网友  发表于 2018-7-23 18:02:52
不错,好的资料不多。感谢提供
使用道具
编程吧网友  发表于 2019-1-17 05:57:48
感谢提供
使用道具
编程吧网友  发表于 2019-1-17 05:58:58
太帮了,感谢楼主分享
使用道具
编程吧网友  发表于 2019-1-17 05:59:48
太棒了,感谢楼主分享
使用道具
