那智Nachi机器人CFD控制装置 操作说明书 移动功能
目         录
1章 概要
1.1 所谓移动功能...........................................................................................
1.1.1 概要.................................................................................................
1.1.2 常用术语..........................................................................................
1.2 准备..........................................................................................................
2章 应用命令
2.1 SHIFTR:移动(FN52).............................................................................
2.2 LOCCVT;座标转换/偏离量(FN53).......................................................
2.3 LOCCVT1:座标转换/座标值(FN54).....................................................
2.4 SHIFTA:XYZ移动(FN58)......................................................................
2.5 LETR:代入移动量(FN68).....................................................................
2.6 ADDR:合计移动量(FN69).....................................................................
2.7 CHGCOORD:移动座标系选择(FN113).....................................................
2.8 GETSFT:代入实数变数/移动(FN145).................................................
2.9 LEFTY:左臂系统(FN161).....................................................................
2.10 RIGHTY:右臂系统(FN162)..................................................................
2.11 ABOVE:肘上侧系统(FN163)..................................................................
2.12 BELOW:肘下侧系统(FN164)................................................................
2.13 FLIP:腕触发系统(FN165)..................................................................
2.14 NONFLIP:腕非触发系统(FN166)..........................................................
2.15 FRANGE:凸缘轴基准角度(FN202).......................................................
2.16 REGC:移动寄存器拷贝(FN224)............................................................
2.17 RINT:机器人挤进I信号(FN29).........................................................
2.18 SEA:检索(FN59)................................................................................
2.19 CLRREGWR:清除移动寄存器的写入状态(FN699).................................
2.20 通过SIGREQ:移位量获取(信号)(FN723)...........................................
3章 便利的機能
3.1 位移监视器...............................................................................................
3.1.1 当前移动中的显示...........................................................................
3.1.2 监视器当前移动量...........................................................................
3.1.3 监视器当前位移寄存器的内容.........................................................
3.2 移动量的手动复位/预设.........................................................................
3.2.1 通过位移寄存器监视器直接编辑.....................................................
3.2.2 快捷方式R162:移动量变更...........
3.2.3 快捷方式R163:移动取消..............
3.2.4 快捷方式R350:移动寄存器清除...
3.3 移动执行中的记录操作............................
3.3.1 请注意移动中的位置记录・修正....
3.3.2 移动量取消步骤记录的设定............
3.4 在步骤0上的移动寄存器清除.................
3.4.1 自动清除位移寄存器的内容............
3.4.2 步骤0移动寄存器清除的设定........
4章 故障处理
4.1 异常检测与对策.................................
1.1  所谓移动功能
1.1.1  概要
所谓移动功能,指的是按照来自外部的要求,将“作业程序的记录位置”即时移动到“追加计入了指定移动量
位置”上的功能。不必改写作业程序中所记录的位置(编码器数据) ,在再生时暂时移动位置。
为了让机器人执行移动动作,需要向机器人传输移动所需的距离及角度(以后,称为“移动量” 。 )相关的信
这一移动量信息,可通过视觉传感器等外部装置获取,也可以事先记录到应用命令中。
打开资源压缩包,里面也有解释说明文字和解压密码;
下载地址为(为增加交流,隐藏的下载地址回复可见):
大神点评(1)
