3D打印SOLIDWORKS 3D模型下载
当前3D模型通过Solidworks2016编辑打开。
并进行了3D效果演示操作。
正在设计相关机械图纸的朋友,可以通过效果图,
判断当前模型是否对自己有所帮助。
当前板块全部素材匀通过百度网盘下载。
下面是当前3D模型的gif格式图片。
下面是下载模型后,目录的全部文件:
Acrylic Side Cover.SLDPRT
cover angled front.SLDPRT
cover back.SLDPRT
cover front.SLDPRT
cover side.SLDPRT
cover top.SLDPRT
front window panel.SLDPRT
Makerbot_Replicator_including_canopy.SLDASM
MP0190_M3_Washer.SLDPRT
MP02690-.355-46-thick-3.175-mm-ID-7.95-mm-OD_Washer.SLDPRT
MP02728_Support_Blind_Hole_Mount.SLDPRT
MP02827_Nylon_4-40_screw.SLDPRT
MP02828_Nylon_hex_nut.SLDPRT
MP138-Type_K_Thermocouple.SLDPRT
MP1531-ABS_black-1kg_spool-1.75mm.SLDPRT
MP1532-ABS_natural-1kg_spool-1.75mm.SLDPRT
MP1606-Motor_Wiring_Harness_42inch.SLDPRT
MP1701-MK7-Thermal_Barrier.SLDPRT
MP1703-MK7-Filament_Drive_Block_Back.sldprt
MP1705-MK7-Thermal_Core.sldprt
MP1707-MK7_Plunger.SLDPRT
MP1708-MK7_heatsink.SLDPRT
MP1709-M3x3mm_set_screw.SLDPRT
MP1710-M3x5mm_socket_cap_bolt.SLDPRT
MP1782-Kapton_Tape_120mm.SLDPRT
MP1794-MK7_filament-drive-block-front.sldprt
MP1868-Pulley_5mm_shaft.SLDPRT
MP1872-Stepper_Motor_NEMA17.SLDPRT
MP191-M3x10mm_socket_cap_bolt.SLDPRT
MP1913-M3x18-Flat_Head_Socket_Bolt.SLDPRT
MP1914-Washer-.16in_ID-.25in_OD-.015in_thickness.SLDPRT
MP1915-O_ring-.14in_ID-.246in_OD.SLDPRT
MP193-M3x20mm_socket_cap_bolt.SLDPRT
MP1947-M3x45-Socket_Cap_Bolt.SLDPRT
MP1994-MK7-Drive_Gear.SLDPRT
MP2193-Thing-O-Matic_2_Top_Panel.SLDPRT
MP2194-Thing-O-Matic_2_Front_Panel.SLDPRT
MP2195-Thing-O-Matic_2_Bottom_Panel.SLDPRT
MP2196-Thing-O-Matic_2_Back_Panel.SLDPRT
MP2198-Thing-O-Matic_2_Left_Panel.SLDPRT
MP2199-Thing-O-Matic_2_Right_Panel.SLDPRT
MP2256-Silicone_keypad.SLDPRT
MP2295-M3-Square_nut.SLDPRT
MP2313-Stepper_motor_acme_threaded_285mm.SLDPRT
MP2322-RGB_LED-Strip_Common_Anode.SLDPRT
MP2336-Thing-O-Matic-2-Z-Arm-Lasercut-Plate.SLDPRT
MP2337-Thing-O-Matic-2-Bottom-Wooden-Build-Platform.SLDPRT
MP2338-Thing-O-Matic-Heater_Board.SLDPRT
MP2339-Thing-O-Matic-2-Aluminum-Heat-Spreader.SLDPRT
MP2340-Dowel_Pin_5-32_inch_OD,_1_inch_length.SLDPRT
MP2343-Botstep_17_Rev_E.SLDPRT
MP2344-MK7_Filament_Drive_Block.SLDPRT
MP2347-Fan_24V_40x40x10-1m_leads.SLDPRT
MP2367-Thing-O-Matic_2_Extended_Rod_Cover.SLDPRT
MP2375-Thing-O-Matic_2_Cut_Rod_Guide_Ring.SLDPRT
MP2378-Thing-O-Matic_2_Inner_Back_Panel.SLDPRT
MP2381-Shaft_8mm_x_300mm.SLDPRT
MP2383-Z_Axis_Acme_Nut_Tr8x8(P2).SLDPRT
MP2384-Thing-O-Matic-2_Build_Platform_Outer_Back_Panel.SLDPRT
MP2403-293_Tooth_GT2_Timing_Belt.SLDPRT
MP2405-83_Tooth_GT2_Timing_Belt.SLDPRT
MP2407-Thing-O-Matic_2_Extended_Rod_Guide_Ring.SLDPRT
MP2414-Thing-O-Matic_2_Extruder_Carriage-nobeltclip_2.SLDPRT
MP2415-Thing-O-Matic_2_Y_Carriage_Secondary.SLDPRT
MP2416-Thing-O-Matic_2_Y_Carriage_Primary.SLDPRT
MP2417-Thing-O-Matic_2_Z_Arm.SLDPRT
MP2441-Linear_Bearing-8mm_ID-15mm_OD-17mm_length.SLDPRT
MP2453-Thing-O-Matic_2_Radial_Ball_Bearings.SLDPRT
MP2458-Belt_Tensioning_Torsion_Spring.SLDPRT
MP2459-M3_Thumb_Nuts.SLDPRT
MP2467_1-2_inch_wire_wrap.SLDPRT
MP2468-Thing-O-Matic_2-Build_Platform_Front_Cover-replicator.SLDPRT
MP2488-Thing-O-Matic_2-Build_Platform_Leveling_Springs_Stainless_Steel.SLDPRT
MP2506-MK8_nozzle_0.4mm.SLDPRT
MP2580-Cable_holder-Adhesive_backed-Self_closing.SLDPRT
MP2583-Foot_edge_neoprene.SLDPRT
MP2584-PTFE_tubing-1-4in_OD-1-8in_ID.SLDPRT
MP2590-MK8-Bar_Mount.SLDPRT
MP2603-Endstop_Cable_1m.SLDPRT
MP2604-Motor_Wiring_Harness_12in_Moons.SLDPRT
MP2607-Cartridge_Heater_40W_24V_right_angle_exit.SLDPRT
MP2660-Spacer_Black-1-2in_length-.14in_ID-.25in_OD.SLDPRT
MP2662-Spacer_Black-3-4in_length-.14in_ID-.25in_OD.SLDPRT
MP2664-Spacer_Black-22mm_length-.14in_ID-5-16in_OD.SLDPRT
MP2665-Spacer_Black-1-16in_length-5mm_ID-7mm_OD.SLDPRT
MP2666-Spacer_Black-11-16in_length-5mm_ID-7mm_OD.SLDPRT
MP2667-Spacer_Black-5-16in_length-.14in_ID-.25in_OD.SLDPRT
MP2669-26_pin_ribbon_cable.SLDPRT
MP2670-26_pin_female_header.SLDPRT
MP2671-O_Ring_Spacer-1.5mm_thickness-3.5mm_ID-6.5mm_OD.SLDPRT
MP2675-Tube_fitting-push_to_connect-drill_in_stall-.45in_tube.SLDPRT
MP2680-#4_Washer-Black_Oxide_Finish.SLDPRT
MP2683-Clamp-Hinged-Blind_hole_mount-Black.SLDPRT
MP2684-Cable_clamp-Blind_hole_mnt.SLDPRT
MP2685-Spacer_Black-16.5mm_length-3.2mm_ID-7mm_OD.SLDPRT
MP2690-Washer-.355-.46mm_thickness-3.175mm_ID-7.95mm_OD.SLDPRT
MP2692-M3x31mm_socket_cap_bolt.SLDPRT
MP2693-M3x12-Flat_Head_Socket_Bolt.SLDPRT
MP2717-M3x35-Flat_Head_Socket_Bolt.SLDPRT
MP2720-Mean_Well-GS220A24_R7B-Power_Supply.SLDPRT
MP2729-Makerbot_MightyBoard-Rev_E.SLDPRT
MP2738-Replicator_Interfaceboard-RevB-PCBA.SLDPRT
MP2751-M3-nylon_inserted-hex_nut.SLDPRT
MP2752-424_Tooth_GT2_Timing_Belt.SLDPRT
MP2753-Shaft_8mm_x_424mm.SLDPRT
MP2754-Shaft_4.99mm_x_464mm-Carbon_Steel.SLDPRT
MP2768-M3x30-Flat_Head_Socket_Bolt.SLDPRT
MP2774-M3x35mm_socket_cap_bolt.SLDPRT
MP2935-Filament_Spool_Holder.SLDPRT
MP370-M3x16mm_socket_cap_bolt.SLDPRT
MP429-Ceramic_Tape.SLDPRT
MP546-M6_nut_thin.SLDPRT
MP856-M3x25mm_socket_cap_bolt.SLDPRT
MP919-M3x6mm_socket_cap_bolt.SLDPRT
MP977-Thingomatic_Idler_Pulley.SLDPRT
MP979-Mechanical-Endstop.SLDPRT
Nylon_Spacer_with_Flange.SLDPRT
Replicator_including_canopy.STEP
SD card.SLDPRT
Side_Clip_Short.SLDPRT
test electronics cover.SLDPRT
test electronics side.SLDPRT
Wire-Filament Extruder Guide.SLDPRT
下载附件后,打开TXT附件可以看到:
1.3D模型解压密码;
2.3D模型下载地址;
