我们知道窗口大小发生变化时,会触发消息WM_SIZE我们就可以在此消息处理函数中改变控件的大小。
例如我们对话框上有一个列表控件IDC_LIST
初始化时我们可以设置一下它的窗口大小
- //获得客户区坐标
- CRect rect;
- GetClientRect(&rect);
- //移动窗口
- CWnd* pWnd = GetDlgItem(IDC_LIST);
- if (pWnd != NULL)
- pWnd->MoveWindow(10, 10, rect.Width() - 20,rect.Height() - 20);
复制代码 当主窗口大小发生变化时,我们可以基其WM_SIZE消息处理函数内对应更改控件大小。
- void CDemoDlg::OnSize(UINT nType, int cx, int cy)
- CDialog::OnSize(nType, cx, cy);
- //根据父窗口的大小移动窗口
- if (pWnd != NULL)
- pWnd->MoveWindow(10, 10, cx - 20, cy - 20);
复制代码 nType表示窗口尺寸变化的类型,有最大化SIZE_MAXIMIZED 。最小化等等。
另外两个参数表示窗口新的客户区大小。
这个函数可以查阅MSDN
afx_msg void OnSize( UINT nType, int cx, int cy );
Parameters
nType
Specifies the type of resizing requested. This parameter can be one of the following values:
SIZE_MAXIMIZED Window has been maximized.
SIZE_MINIMIZED Window has been minimized.
SIZE_RESTORED Window has been resized, but neither SIZE_MINIMIZED nor SIZE_MAXIMIZED applies.
SIZE_MAXHIDE Message is sent to all pop-up windows when some other window is maximized.
SIZE_MAXSHOW Message is sent to all pop-up windows when some other window has been restored to its former size.
cx
Specifies the new width of the client area.
cy
Specifies the new height of the client area.
