屏通触摸屏与SIKO-SIKONETZ5通讯线制作与通讯参数设置
图文介绍文档在下边可下载。
SIKO-SIKONETZ5 Port
此技术文件用于说明当使用触控屏时,如何与马达控制器正确进行连线以及相关设置需要
注意的事项。
(适用于SIKO-SIKONETZ5 通信协议系列,本文件以 AG05实测)
SIKO 马达控制器 setting
1.  AG05马达控制器设置:
马达通讯参数(须与 HMI相同)
参数功能表  說明
参数  功能  设定  设定范围
ID  Node address    1  0 - 31
bAUd  Baud rate    576
576: 57600 baud
1152: 115200 baud
192: 19200 baud
PrtcL  Protocol    Sn5
Sn5: SIKONETZ5
SEruC: Service protocol
bUSto  Bus Timeout    20  Value range: 0 - 20
HMI Setting
1.  选择Device/Server Setting: SIKO Ltd---AG05 (SIKONETZ5) 设定
通讯设定:参数须与马达相同(Baud Rate 预设:57600)
PLC Device List
Word Devices:
资料暂存器位址及内容
AG05 系列参数对应表
参数  名称  属性  支援物件  数据类别  說明  备注
00    Node address    RW  Numeric Entry  Unsigned8    Value range 0 – 31
01    Baud rate    RW  Numeric Entry  Unsigned8
0 = 19200
1 = 57600
2 = 115200
02  Bus Timeout    RW  Numeric Entry  Unsigned16    Value range 0 – 20
03
Reply parameter
to Write set point command
0 = Set point
1 = Actual value
2 = Output stage temperature
3 = Control voltage
4 = Output stage voltage
5 = Battery voltage
6 = Motor current
7 = Actual position
8 = Actual rotational speed
04    Enable keys time    RW  Numeric Entry  Unsigned8  Value range 1 – 60
05
Key function
enable
R/W
Numeric Entry
Switch
Unsigned8
0 = key function free
1 = key function locked
07  LED 2 orange    R/W
Numeric Entry
Switch
Unsigned8
0 = LED2 Off
1 = LED2 On
08  LED 1 red    R/W
Numeric Entry
Switch
Unsigned8
0 = LED1 red Off
1 = LED1 red On
09  LED 1 green    R/W
Numeric Entry
Switch
Unsigned8
0 = LED1 green Off
1 = LED1 green On
0A  Decimal places    R/W  Numeric Entry  Unsigned8  Value range 0 – 4
0B  Display divisor    R/W  Numeric Entry  Unsigned8  Value range 0 – 3
0C  Direction indication function    R/W  Numeric Entry  Unsigned8  Value range 0 – 2
0D  Display orientation    R/W
Numeric Entry
Switch
Unsigned8
0 = normal
1 = rotated by 180°
0E
Programming mode
Configuration
R/W
Numeric Entry
Switch
Unsigned8
0 = no programming mode
1 = apply programming mode
0F  PIN change    R/W  Numeric Entry  Unsigned32    Value range 0 – 99999
10
Controller parameter
P
R/W  Numeric Entry  Unsigned16    Value range 1 – 500
11
I
12
D
13  a – Pos    R/W  Numeric Entry  Unsigned8    Value range 1 – 100
14  v – Pos    R/W  Numeric Entry  Unsigned8
Gear 66:1, 50W- - 75
Gear 98:1, 50W- - 50
15  a – rot    R/W  Numeric Entry  Unsigned8    Value range 1 – 100
16  a – inch    R/W  Numeric Entry  Unsigned8    Value range 1 – 100
17  v - inch    R/W  Numeric Entry  Unsigned8
18  ü - Numerator    R/W  Numeric Entry  Unsigned16    Value range 1 – 10000
19  ü - Denominator    R/W  Numeric Entry  Unsigned16    Value range 1 – 10000
1A  Encoder resolution    RO  Numeric Entry  Unsigned16    Constant Value 720
1B  Sense of rotation    R/W
Numeric Entry
Switch
Unsigned8
0 = i sense of rotation (cw):
1 = e sense of rotation (ccw)
1C  Spindle pitch    R/W  Numeric Entry  Unsigned16  Value range 0 - 1000000
1E  Offset    R/W  Numeric Entry  Unsigned32  Value range -999999 – 999999
1F  Calibration value  R/W  Numeric Entry  Unsigned32  Value range -999999 – 999999
20  Pos- window    R/W  Numeric Entry  Unsigned16  Value range 0 – 1000
21  Pos type    R/W  Numeric Entry  Unsigned8
0 = direct
1 = loop +
2 = loop -
22  Loop length    R/W  Numeric Entry  Unsigned16  Value range 0 – 30000
23  Inpos mode    R/W  Numeric Entry  Unsigned8
0 = position control
1 = short circuit of the motor windings
2 = motor activated
24  Delta Inch    R/W  Numeric Entry  Unsigned32  Value range -1000000 – 1000000
25
Acceleration
type with
Inching mode 2
R/W
Numeric Entry
Switch
Unsigned8
0 = static acceleration
1 = incremental acceleration
26  Inching 2 Offset    R/W  Numeric Entry  Unsigned8  Value range 10 – 100
27  Stop mode inching 2    R/W
Numeric Entry
Switch
Unsigned8
0 = maximum deceleration
1 = programmed deceleration
28  Operating mode    R/W
Numeric Entry
Switch
Unsigned8
0 = positioning mode
1 = speed mode
29  Limit 1    R/W  Numeric Entry  Unsigned32  Value range -9999999 – 9999999
2A  Limit 2  R/W  Numeric Entry  Unsigned32  Value range -9999999 – 9999999
2C  Current limiting    R/W  Numeric Entry  Unsigned32  Value range 25 – 110
2D  Contouring error limit    R/W  Numeric Entry  Unsigned16  Value range 1 – 30000
30
Display value of
2nd line
0 = Set point
1 = Output stage temperature
2 = Control voltage
3 = Output stage voltage
4 = Battery voltage:
5 = Motor current
6 = Actual position
7 = Actual rotational speed
33  Display divisor application  R/W
Numeric Entry
Switch
Unsigned8
0 = The display divisor will be applied to the
interface’s  target  and  actual  positions  and  tot
he display.
1 = The display divisor will be applied to the
display only.
60  Output stage temperature    RO  Numeric Entry  Integer16    Temperature values in 1/10 °C
61  Voltage of control    RO  Numeric Entry  Integer16    Voltage values in 1/10 V
62  Voltage of output stage    RO  Numeric Entry  Integer16    Voltage values in 1/10 V
63  Voltage of battery    RO  Numeric Entry  Integer16    Voltage values in 1/100 V
64  Motor current    RO  Numeric Entry  Integer16    Current values in mA
65  Device code    RO  Numeric Entry  Unsigned8  0 = AG05
66
Display controller software
version
Version number
e. g. 103 corresponds to V1.03
67
Motor controller software
version
Version number
e. g. 108 corresponds to V1.08
68  Serial number    RO  Numeric Entry  Unsigned32  Serial number
69  Production date    RO  Numeric Entry  Unsigned32
Production date in DDMMYYYY
format
6A  Gear reduction    RO  Numeric Entry  Unsigned16
66 = gear 66:1
98 = gear 98:1
6B  Actual position    RO  Numeric Entry  Integer32
Spindle pitch = 0
values in increments
Spindle pitch > 0
values in 1/100 mm
6C  Actual rotational speed    RO  Numeric Entry  Integer32  Actual speed in rpm
80  Number of errors    RO  Numeric Entry  Unsigned8
Returns the number of errors in the error
memory
81  Error 1    RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
82  Error 2  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
83  Error 3  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
84  Error 4  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
85  Error 5  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
86  Error 6  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
87  Error 7  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
88  Error 8  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
89  Error 9  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
8A  Error 10  RO  Numeric Entry  Unsigned8  see chapter 7.2.1: Error codes
A0  S command    WO  Numeric Entry  Unsigned16
1 = all parameters to default
Caution! All parameter classes will be reset.
After restart, the factory settings will be active,
this applies to node address and baud rate as
well.
2 = only standard parameters to default
3 = controller parameters to default
4 = display parameters to default
5 = bus parameters to default
6 = reset error
7 = calibration
8 = delete error memory
9 = software reset
A8
Programming mode
On / Off
temporary
WO
Numeric Entry
Switch
Unsigned8
depending on the programming mode
configuration parameter
Programming mode configuration = 0
no function
Programming mode configuration = 1
0 = Programming mode Off
Write parameter disabled.
Write attempts are acknowledged with an error
message.
1 = Programming mode On
Write parameter enabled
AA  Freeze actual value    WO
Numeric Entry
Switch
Unsigned8
1 = freeze actual value The current actual
value is cached until next reading of actual
value
CA
Switching the
bus protocol
WO
Numeric Entry
Switch
Unsigned8
Configuration of bus protocol
0 = SIKONETZ5
1 = Service protocol
Parameter changes become active only after
cold start or software reset.
FA  System status word    RO  Numeric Entry  Unsigned16  System Status Word
FE  Actual value    RO  Numeric Entry  Integer32
Positioning mode
Actual position
Rotational speed mode
FF  Set point    RW  Numeric Entry  Integer32
Positioning mode
target position
target rotational speed
接线图
Cable Diagram
HMI Com1         AG05
D-Sub 9pin male
TX+  1    2  TXRX+
  2    1  TXRX-
  3
  4
  5
TX-  6
  7
  8
  9
HMI Com2        AG05
B Type 5 pin
RS485+  1    2  TXRX+
RS485-  2    1  TXRX-
查看状态:需购买或无权限
您的用户组是:游客
文件名称:屏通触摸屏与SIKO-SIKONETZ5通讯线制作与通讯参数设置.rar
文件大小:1.18 MB
下载权限: 新手上路 以上或 VIP会员   [购买捐助会员]   [充值积分]   有问题联系我
