欧姆龙E5EZ-PRR位置控制器用户使用操作手册高清中文版
《欧姆龙E5EZ-PRR位置控制器用户使用操作手册高清中文版》
大概内容为:
前言.........................
使用时的注意事项.
安全注意事项.........
安全使用注意事项.
本手册规约.............
第一章   简介···········
1.1 部件名称············
E5EZ-PRR 面板···
显示器···············
按键使用方法····
1.2 输入/输出组态和主要功能····
输入/输出组态········
主要功能·························
1.3 设置菜单组态和面板按键操作·····
选择参数··················
固定设置···········
1.4 通信功能····
第二章   准备工作······
2.1 安装·········
E5EZ-PRR 尺寸··
E5EZ-PRR 面板安装孔·····
E5EZ-PRR 装配···············
将 E5EZ-PRR 安装到面板的方法···
2.2 接线端子··························
E5EZ-PRR 连线·········
接线注意事项··········
接线·····················
事件输入·············
通信···············
通信··············
2.3 安装要求···················
确保更长的使用寿命··············
减少噪声影响···················
确保高精度测量·
第三章  基本操作·
3.1 初始设置示例·········
3.2 设置输入类型········
输入类型············
3.3选择 / ℃℉·············
温度单位··············
3.4 设置输出规格···
正/逆操作·············
3.5 设置 SP··············
更改 SP ·····················································
3.6 确定 PID常数(AT 及手动设置)·········
AT(自动调整)······································
手动设置···················································
3.7 报警输出··············································
报警类型···················································
报警值·······················································
报警延时···················································
3.8陶瓷窑的位置比例控制······················
应用实例···················································
布线··························································
设定··························································
调整··························································
位置比例控制的固有设定·······················
3.9 手动控制时··············································
3.10操作要求·············································
第四章  应用操作································
4.1 输入偏移值··········································
输入偏移···················································
输入偏移值(2 点偏移)的计算方法·····
1 点偏移法················································
2 点偏移法················································
2 点温度输入偏移示例····························
4.2 报警滞后··············································
待机顺序···················································
报警闭锁···················································
报警时关闭/报警时开启··························
报警操作概述···········································
报警延时功能···········································
4.3 校准上下限(模拟信号输入)··········
模拟信号输入··············································
4.4 使用事件输入··········································
设置事件输入··············································
多重设定值使用方法··································
按键操作设置··············································
设置·····························································
执行运行/停止控制·····································
4.5 设置 SP上下限值···································
设定值限制··················································
4.6 执行SP斜坡功能(限制 SP变化率)
SP斜坡························································
4.7 转换到高级功能菜单······························
4.8 使用按键保护菜单··································
按键保护······················································
第五章   参数·····················
本章规约··························
本章中图标的含义··········
参数显示··········································
本章中的参数说明顺序··················
手动控制菜单··································
保护菜单··········································
运行菜单··········································
调整菜单··········································
初始菜单··········································
高级功能菜单··································
通信菜单··········································
附录···················································
规格·························································
额定值··················································
特性·····················································
错误显示·················································
参数操作表·············································
传感器输入设置和指示范围················
设置菜单图·············································
参数流·····················································
索引···················································
下载地址:
